soloQ45 »
https://forums.nicoclub.com/soloq45-u145863.html
Thu Oct 13, 2011 10:44 am
Belt Tension was fine, wear was nominal.
I suspected a failed solenoid...but then, I was using a 1994 shop manual, and I have a 1996 (manufactured 1995) vehicle. Is there a big difference?
Meanwhile, a couple of senior technicians figured it out on a lift. The U-joint in the steering column has lost lubrication and so the action is very stiff. The guys were able to deduce this because the steering went stiff in at standing turn at the 11AM and 1PM positions. That's the difference between a novice (your's truly) and the pros...
Steering's now a dream...though I was warned that because the U-joint is next to the catalytic converter; the heat from the converter is evaporating the lubrication...so it's a matter of time before the stiffness returns.
Now I need to find a good used u-joint to replace the other ones.
Thanks for all your advice.
