hansQ45 wrote:Wes, thanks for the info.
Do you think I should order the valve cover gaskets from Joe in Arizona? And the NGK Lazer Platinum plugs from you (Q45.org)? Do I need any additional parts?
The previous owner told me he had an expensive "tune up" done at about 100,000. He told me he had the spark plugs changed. I don't know if he went with the NGK Lazer Platinum plugs you all highly recommend on Q45.org and NICO.
Do you just remove the covers with the allen head bolts and the spark plugs are under the cover? Isn't there a coil for each plug?
Anything to really be careful of in doing this job? Valve cover gaskets too?
I saw the Great Hoosier state is pretty rough right now, weather wise.
I dont want to sound like im trying to sell you stuff, but I might go ahead and get them.. If you dont need them (IE you have NGKs in there now) then youll have them for 30k... You sound like you put quite a few miles on the car, so you can hang on to them for about a year and a half and replace, or replace them now and be set of 60k.. if you have el crap O ones in there
Youll want to get some RTV and RTV the half moons. I didnt do it on my last one but you probably want to... Just get some carb cleaner and clean out the valve covers really good, AND take pictures of the heads when you take off the covers...
