1996 Q45, How do you remove ECU?
jedi_sol
Car: 1996 Infiniti Q45
I've searched and searched in the FSM and I just can't find it anywhere.
I'm trying to reset the ECU. So far, I've removed the plastic kick panel cover, the bolt in the back, one screw near the front bottom, one screw near the front top. I'm tugging in every direction but the ECU still won't budge. Am I missing a screw?
Thanks,James
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
you gotta lift it up then it should come right out.
str8flush
Car: 1995 Q45
By RH kick panel, do you mean the passenger side floor board where the carpeted cover is removed???
Q45tech
1996 ecu is OBD2 you use an expensive scan tool to reset and read parameters and codes unlike 90-95 which requires a Consult.
