1996 Q45 ECU codes: 32, 77, & 78 Help!!!!!!!
blacklist74
Car: 1994 Infiniti Q45
I'm having problems with these codes. I changed the EGR valve, but still getting a code 32 (EGR Function). What should I look for? Another problem is code 77 (Rear Heated Oxygen Sensor). Where is that located? Last problem is code 78. I don't know what code 78 is.......do you? I just changed the Knock sensors two day ago.. Trying to clear all the alarms(codes).. Help me out guys!!!!!!!!
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Try downloading the FSM and TSB from http://www.nissan-techinfo.com/infiniti/ for a one day subscription. A little reading and your questions and more will be answered.
Operational questions are best posted in Infiniti Online Mechanic.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Moved the thread to the Infiniti online mechanic...
Have you cleaned the EGR passage? IF its completely blocked then youll still throw a code because the EGR temp sensor is getting no EGR through it..... Most times the valve is fine, clean things up...
77 and 78 are for the rear o2 sensors. they are located just behind the cats.
blacklist74
What do you clean the EGR passage with?
blacklist74
I have the big Infiniti Q45 (1996) service manual... What do I look for?
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Read EC. Codes start at EC-296.
Q45tech
Unfortunately our trained gerbiles with miners lights are too large to fit in the passage from EGR valve up and into plenum.............small cylindrical wire brush, we use a home made mini rotor rooter........out of flex cable and a drill........mini pick axes and jack hammers [sometimes]........Dremel tool with flex drive.
Same situation with every engine that has used EGR since 1970's.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
I have been searching high and low for that cable with the chuck on the end.
