qship96 »
https://forums.nicoclub.com/qship96-u3104.html
Tue Jul 30, 2013 1:35 pm
Slow down.....first of all,4 years of battery life is above average in a Q-I NEVER got over 3 from a OEM battery,and I have replaced many in this old boat.
Regarding amp draw in these cars,one has to be very careful how{and WHEN} you measure it,as there are many microprocessor driven features that continue to draw amps after the car is shut off for several minutes until they go into "sleep mode"......not to mention,just having the hood up draws amps due to the security system hood switch being activated.....very tricky to measure "true" amp draw while car is truly "at rest"- I suggest a battery pigtail hooked to a digital multimeter with cable run in a way that allows you to close the hood/lock the doors and wait 10 minutes for all microprocessors to enter sleep mode before attempting to measure an accurate reading.
