elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Sat Feb 23, 2013 7:49 am
HID's don't work so well in enclosures that were originally designed for standard filament bulbs.. You can do it, but it won't really gain you a ton. The "headlight inoperative" message will also plague you unless you're crafty and trick the system. I have silverstar ultra's in my car, and I think the headlights on the 1st gen Q are fantastic, so I've not been compelled to change anything!
Also LED's in turn signals will not work properly, they will blink fast like a bulb is out. I've also heard that the performance isn't as good because of the way the enclosures are designed.. An LED only outputs light as a direct beam, where a filament bulb is basically omni-directional.
I'm not shooting you down, but just know it's not going to be a "plug and go" situation.
