VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Wed Nov 17, 2021 10:02 am
See if you have voltage at the White/Black wire coming into the Ignition Switch. If not, Fusible Link G is blown. If W/B is hot, check the Black/Yellow wire coming out of the Ignition Switch when you turn the key to the start position. If it doesn't go hot then the switch is bad. If both of those check out, on an M/T the Clutch Relay is in the Relay Box on the passenger fender. It should have two Black/Yellow wires, a Blue/Green, and a Black/Pink. Both B/Y's should go hot with the key in Start, if not there's a broken wire between the Ignition Switch and the relay. If B/Y goes hot, jump B/Y to B/P with the relay removed and the transmission in N or the clutch pulled. If the starter spins with the key when the relay is jumped, the problem is in the relay circuit. The clutch switch needs to ground the L/G wire, so check that the switch has ground and that L/G isn't broken someplace between the relay and switch.
