I'm 100% sure you can find a used SECU at an auto recycler for really cheap.
1. Go to
http://www.car-part.com2. Select your year and make/model from drop down boxes.3. For part, select Computer Box Not Engine.4. For Area, select USA under Countries (you can also select a more specific area like your state or even a city near you, I use USA simply because most likely you can get any of the auto recyclers to ship the item to you, enabling you to select the lowest price one).5. On the next screen, select Theft/Locking (select either with or without theft warning system depending on your original equipment)
The next screen will show you all of the parts available, there should be quite a bit. Some list SECU's pretty cheap. I would call and ensure that the one you want is actually the SECU and ask if the auto recycler has any sort of return policy if DOA.
Let me know if this works for you!
