1996 obd2 motor into 1995 car?
EckOMaN2k
Hmmm i did some searching an cant really find a answer as to what is needed for me to swap a 1996 obd2 motor into my 1995 240sx. But a buddy of minds said it should all bolt up an work just fine as long as i use my 1995 intake manifold, is this true?
1991S13
Car: '91 240sx Coupe, '00 QX4 4x4, '02 Sentra Spec V
I was told that you get a harness that plugs into the existing harness going to the old ECU that will allow it to plug into the OBDII ECU. Everything will be good, but if they plug it in at emissions time it will not pass because of different sensors.
midnightsliding
its should work, if you your stock exhaust manifold and intakemanifold. so all you need is the block and head to do your swap and use exsiting sensors and manifolds.hope this helps any
