NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Mon Jan 26, 2004 4:55 pm
unfortunitly the oring that goes bad in the dist. is not servicable thats why they recommend the dist. have done many of them in altimas. the Intake gasket is also another common problem with the altima. I dont recommend going to a gas station for that repair as I have seen even the best nissan techs hose that job up. It is a very difficult and tedious job. If you do get it done make sure to replace the oring in the water jacket coming straight down off the intake on the passenger side[It is very common to leak coolant from it and only takes to seconds to do once the manifold is out of the car. what that pipe feeds into has a plastic vaccum switch and its ports tend to get broken by inexperianced techs doing the job. This is one of the reasons I dont recommend the gas station as well.
