buttercup2511 »
https://forums.nicoclub.com/buttercup2511-u194260.html
Fri Nov 25, 2011 10:55 am
I have a 96 nissan pickup. Once the truck warms up it's starts idling rough and stalling once you push the clutch in. I have replaced the distributor and the fuel pump/sending unit. the check engine light is on the codes are o2 sensor and purge valve canister. We disconnected the o2 sensor and the truck ran good for a while then started acting up again. I wanted to know if I need to replace the mass air flow sensor or maybe the air temperature sensor?
