k3n12ock »
https://forums.nicoclub.com/k3n12ock-u94163.html
Mon Apr 07, 2008 4:36 pm
Hey everyone. I have a few questions an I am wondering if anyone can help me.
1. I am having real bad problems with my Pathfinder. It revs real high, about 3200 , before it switches from 1st to 2nd. Once I hit 40 MPH, the RPM is at about 4500 and then jumps all the way to 5500 RPM. At 6000 RPM I am barely picking up any speed. It then starts to drop in speed regardless of how much gas I give it.
2. My check engine light is on and when I went to Advanced their machine said that i am getting code error 0220, which is a Pedal/Throttle Position Sensor failure. I have since then replaced it yet I am still having the same problems. Could it possibly be the connectors to the TPS? Could I possibly buy aftermarket ones and replace them? My brother told me that it could be the Mass Air Sensor also. Is there any way to test a bad mass air sensor? I wanted to consult you guys before I spent $300 on it.
3. My door and tailgate locks are all bad. I tried using some PB Blaster on them but nothing still. After, I removed the front passenger door panel. My question is, how do I take off the door lock cylinders for the fronts & tailgate? I see no way to remove it.
Thanks for looking and I apprciate any and all replies.
