jcyoung »
https://forums.nicoclub.com/jcyoung-u17885.html
Thu Jul 08, 2004 8:50 am
hello, i have a 1996 nissan pathfinder se 4WD 3.3l with 115,000mi. this car has been the most reliable car i have ever had. the car has run perfect from day 1 until last night. i went into a store for 5 minutes and came back to my car and tried to start it (it wouldn't) it acted like it was still in gear (lights and radio worked)the starter wasn't cranking. a mechanic came by and helped me. he switched the relay switches and that didn't work. he used speaker wire to directly jump the starter so i could get home (check engine light stayed on) we directly jumped the starter again this morning to get it to the garage to get the trouble codesp0600 A/T control & communication line TCM/ECMp1605 diagnosis communication line TCM diag comm line faultthe tech used a snap on 2500 scanner. the garage is about 1/2 mile away and i noticed severe loss of power (maybe due to transmission not shifting into upper gears) could it still be the neutral safety switch without that code activated? any info would be helpful. cheryl
