1996 Nissan Maxima Crank no start
barrybennett
Car: 1996 Nissan Maxima
1996 Nissan Maxima Crank no Start?
Hey guys.
I changed the following out on my car:
-Spark Plugs
-all coil packs
-Camshaft Sensor
-Fuel Filter
-Valve Covers
-Intake Manifold Cover
-Starter
-Battery
Still no start. Fuel pump is kicking on. And the car cranks very quick and strong. Still just won't fire up. We took the spark plugs out after we tried to crank it, and they were covered in fuel. Also smells like fresh fuel when I try to start it. I really need some answers. I have put a little over 700 dollars in the car since December 2013. I just need it to run! Thanks!
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
06 Infiniti M35 Sports
04 G35 & 99 I30-RIP
The engine is probably flooded so additional start attempts will make it worse. You can probably take out the plugs and let the fuel evaporate. Were you able to start the car normally before you replaced all those parts? What is the battery voltage before and during starting? Is the Security LED off with Ignition Switch in ON/Start position. Have you attempted disconnecting the MAF sensor before engine start? Please check the main ground points of the engine harness. IIRC, the ground points (2 ea) are close to the cylinder 2. You can follow the harness and you will find 2 wires connected to the engine frame.
