1996 Nissan Maxima Auto transmission problems
carnal_c30
Car: 2001 QX4 4WD
2002 QX4 4WD
1999 Q45 VIP life
1996 I30 5spd
1998 I30 Auto
1997 Maxima 5spd Supercharged
1995 240SX S14.5
1995 240SX S14
1994 Hardbody KC V6 5spd 4WD
1972 BMW 2002
1972 BMW E9
The car is a 1996 Nissan Maxima GXE 4spd Automatic
the transmission has ~65k miles on it and was from a relatively babied car without boost or nitrous, upon install into the current car at 60k miles the transmission was upgraded with a valve body upgrade and a transmission cooler
The problem- on returning from a trip the transmission started to slip in 1st gear occasionally The car will be stopped in drive and will come out of gear and when gassing it the car will rev freely. Sometimes the transmission will catch and lurch forward, otherwimes I had to put it in park and put it back in drive where the transmission will work again. Once moving the transmission seems to work fin (even though I was a little bit nervous to push it to see if it slipped in all gears but during gentle acceleration there was no slippage in any other gears.
There is a transmission fluid leak that just started recently from back around the pan and it is quite a decent sized leak leaving a 16" diameter oil spot on the pavement in one day.However at the time the car was being driven, the transmission fluid level when checked in park was sufficient
The transmission fluid is in perfect condition but with a slight slight smell of burnt metal
can anyone give me some pointers? The OD light does not blink or anything
I'm wondering could it be the solenoids, lack of fluid pressure (??) or something else!
thanks in advance!
carnal_c30
Car: 2001 QX4 4WD
2002 QX4 4WD
1999 Q45 VIP life
1996 I30 5spd
1998 I30 Auto
1995 240SX S14.5
1995 240SX S14
1972 BMW 2002
1972 BMW E9
any help?? anyone need more info?
