180fan »
https://forums.nicoclub.com/180fan-u3602.html
Tue Mar 07, 2006 9:35 pm
timing, distributor cap/rotor, ignition wires, fuel and air filters, clean the pipings, change the transmission fluid, replace the vac lines, check the intake manifold for a sucked in gasket which can also make startup difficult, always a good idea to clean out the throttle body and intake manifold with carb cleaner and also seafoam. Don't forget the CTS, check the TPS position, IACV, and replace the PCV.
