loystock »
https://forums.nicoclub.com/loystock-u10145.html
Sat Jul 18, 2009 5:25 am
A heater core leak should affect the front, not the rear passenger area. Besides, you can easily distinguish the smell coolant from water. Was it raining when you had this problem? If so, it must be the weatherstripping of your sunroof (assuming the windows are fully closed). You cannot blame your mechanics if he missed it. Check for water spots/stains around the sunroof opening. Do as what Max said and hose down the roof of you car. If no leak is evident, then spray water on the windows and rear glass.
