1996 l30 starter
Tim111
Car: 1996 Infiniti i30
So my car stop starting one day.i looked underneath for the starter wasn't there ,finally found it under the hood,banged on it the car started.So is it difficult to replace the starter,and does anyone know were some pictures or instructions on replacing are,or if some one could walk me through it.i am laid of so i can't afford to take it in.i think I can do it.Any help would be greatly appreciated..
Modified by Tim111 at 2:39 PM 7/17/2007
Modified by Tim111 at 2:50 PM 7/17/2007
maxhopper
Car: 02 Maxima SE 6spd
Welcome to NICO!
The starter is really easy to replace. First take the air piping out. Then you'll need to disconnect the wires from the starter. Next use a 17mm and 14mm rachet to remove the two bolts holding the starter in. Then put the new starter in, reconnect the wires, and reinstall the air piping.
brianw
Car: 4-doors, 5-speeds...
Yep, easy.
http://www.motorvate.ca/mvp.php/516
Especially if you have an aftermarket intake that replaces the factory piping between the TB and MAF and you've already tossed the stock air scoop in the trash (since your aftermarket intake doesn't need it)... takes about 10 minutes.
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
06 Infiniti M35 Sports
04 G35 & 99 I30-RIP
Since you're taking out the air intake manifold, better clean the throttle body and MAF sensor. Use non-residue contact cleaner on the MAF sensor. If it's really dead and not just sticky (dried out grease), be sure to buy an OEM starter. Best pricing is still from Joe (Scottsdale Infiniti).
Rod
Tim111
Thanks for everything.It was easy to get out, and I even found a place in Milwaukee close to my house that will totally rebuild the old one for 75.00 alot of my friends went to this place,and all they do is rebuild starters,and none of them have ever had a problem.It sure is better then the prices I got from the aoto parts stores,they wanted between 150 to 200 bucks.
