ShawnK240sx »
https://forums.nicoclub.com/shawnk240sx-u39972.html
Sun Apr 23, 2006 8:13 pm
I'm at my wits end-any help is appreciated
1996 240sx stock ka24de 5spd
Timing at 20 degrees btdc, the car idles very smooth.it is difficult to start-need to crank it over for about 5 seconds before it catches.
Checked the MAF, getting 1.5v at idle, increased to 3v+ at 4k rpm.TPS voltage checked ok. MAP checked ok. Front and Rear O2 sensors checked ok. New fuel filter, 35psi on the gauge. New plugs and rotor.
If I SLOWLY increase the throttle, the car will go to 4k+ no problem.But if I try ANY aggresive throttle, it will bog, then die.If I increase the timing to 40+, I can drive it around the block, but now it will not idle(surges between 300-1000), and it has a big miss. I could limp it to the dealership for a $95 diagnosis. My scan tool is pulling NO codes, and the CEL is not lit (if I pull the MAF, it lights and kicks a code, so I know it is working)
Printed out the service manual and have checked everything except:ignition module, internal coil, crank sensor, and IACAm I getting closer? Could the MAF cause this even though it is showing valid values when I'm testing it?
Thank you for any help!!!Shawn
