1996 KA24DE ECU pinout guide
doctorj240
Car: Black s14 w/ redtop
I'll be installing the greddy emanage that came with my turbo kit this weekend, and I need the ecu pinout for my 96 KA. My piece of crap Chilton's doesn't have it and I tried searching but only found the 95 pinout guide. I need to know only 6 wires. Power, Ground, RPM, Throttle, MAF input, MAF output. Any help would be greatly appreciated. Thanks.
Jimmy
daniel240
Car: cars/motocross
i may be wrong but isnt it the same for the 95?
doctorj240
I don't believe so. I think that 96 was the first year for a true OBD-II ECU on the 240.
nismofan14
Ok here is what i did when I hooked up my rev speed meter, Look at the 95 pinout and find the wires, check the color of them in the chiltons and then the wire on your ecu in the location it says in the 95 pinout to see if the colors match........the 95 is different but not that much since there are only a few wires that you need to change if you get a jwt ecu for the 97/98....they use a 95 ecu. If you don't feel comfortable then buy a FSM from a dealership, ebay, etc. or try contacting greddy.
