autotech43 »
https://forums.nicoclub.com/autotech43-u4010.html
Thu Sep 04, 2003 2:23 pm
Kiszo, you will get many different theories of the pro's and con's of flushing transmissions. Many folks may or may not know that on some Infiniti vehicles, you may or may not can flush the transmission coolers that are located in the radiator, reason being, on some there are a wire screen webbing in between the cooling tubes that go inside the radiator. Depending on the size of metal or debris will determine whether it will allow flushing of the cooler. If a certain size of debris is present, it will get caught in the wire screen and cause a restriction in the cooler. There ia a tech bulletin regarding this procedure. Some of the coolers will require replacing. Back to your vehicle, your J doesn't have that type of A/T cooler, so your ok there. As far as my theory and experience with overhauling Infiniti/Nissan transmissions, I always look at the fluid (reddish color), see if it has a burnt smell, and how much debris is in the pan and on the magnet located at the bottom of the pan. That lets techs know pretty much what condition the overall transmission is in (also depends on the history/recent maintenance). In your case, if everything looks pretty decent, I would drop the pan, replace the filter and refill with fluid. Buy the sensor before you start, so you can get an idea on what your looking at when you get in there, it's not that complicated to change even for the first timer. I think where alot of techs have differences verse the flush and drop method, some will say you still have dirty fluid mixing in with new fluid when you don't do a complete flush(which is true). They do have machines that push out the old fluid and replenish new fluid behind it, i see no problem with that theory. What i would consider a problem, if the trans has alot of debris and the fluid is burnt and dirty, that could cause debris to get lodged in the valve body, which can cause a severe migraine to the trans. Remember, changing just the fluid and flushing the A/T with a chemical are two completely different operations. I think customers need to ask questions about transmission procedures on exactly what is being done, and not just the routine answer of we serviced your transmission, or backflushed the system. Hope this may help!
