whatchagonnado »
https://forums.nicoclub.com/whatchagonnado-u296700.html
Fri Jun 12, 2020 9:08 pm
Thank you for your response. I made mention this afternoon to my Alt rebuild shop owner that I had 83 looks but no replies. And probably because of my full description of problem and steps already tried to fix it. Then just checking, I see a reply and suggestions from you that I have not given much weight to cause.
So, thank you up front for your input.
Last fall when I replaced the Alt from PS oil contamination, ( a stupid engineer mistake, mounting the Alt bottom of the engine subject to leaking hoses, high water shorting out) I saw the belt was well past its prime, oil soaked, missing sections of ribs, totally in need of replacement. But since I had to pull the PS and AC belts first, decided to put off replacing til another time. That time came on May 27 when I had the car for a day to fix other short ends. Gave car back to grandson on May 29th. One week later; Dead Battery.
I don't have a belt tension tool but just tighten a new belt just enough to keep from squealing and retighten about 500 miles later. Seems to work okay. I used to tighten as you said, (guitar string tight) but one time on a Pontiac Grandville, I did that and the Alt pulley bearing froze and broke the Alt belt. This was in mid Jan while driving from Anchorage to Fairbanks. I made it back home with no heat except for some through the vents with no fan and no lights or other electrical. Cars did not have all the fancy fuel injection or electronic ignition so that got me through. The garage told me too tight caused it and also puts side pressure on the water pump, so from then on I did a just tight enough install.
So tomorrow I will try your suggestions, On surface, they have good merit and appreciate your input.
Looking at the fan clutch, it seems okay with car running but will check it as well as tightening the tension on the belt. I have never done the screwdriver test on a working Alt, in fact never thought about it. I know it is putting out some to get the V to read 12.9 when I increase idle so maybe not enough to cause the screwdriver to get attracted. That test makes me nervous and don't want to see something go wrong and a hole in the radiator or condenser.
What puzzles me is at increased idle V reading is 12.9 but with AC engaged immediately Volts drop to 10.4 with no increase in voltage with increased RPM's or tell tale belt squealing.
Well, with that said, I will close for this session and cross my fingers until morning. Hopefully, ~~~ I can report problem solved thanks to you tomorrow evening. I do have another problem I will address about tire wear another time.
