Quote »PO15 Engine Collant Temp Circuit Malfunction (Not sure what that is)[/quote]It means the engine computer isn't getting a valid signal from the engine coolant temperature sensor - and thus doesn't have any idea what the engine temperature is!
It can make your engine run like crap - and needs to be fixed. Check for a loose connector on the coolant temperature sensor - perhaps you disturbed it while swapping plugs or coil packs?
