Jeff Williams »
https://forums.nicoclub.com/jeff-williams-u431.html
Fri Mar 10, 2006 3:40 am
The previous owner spent a bundle keeping her running, and I have spent a bundle, in hopes of getting a lot of mileage out of her. Here is a synopsis of the service on Lola:
Original Owner:$46,000.00 Purchase$3,500 Re-paint & body work$1,500 estimated maintenance over 3 years
Previous owner:$32,330.34 Purchase$65.90 Oil Change$1,400.54 60K Service (oil, plugs, oil pan gasket, fuel filter, fan, oil pressure switch, brake pads, belts, alignment$47.26 Added ground wire to MAF, oil change$94.25 1 new tire$282.72 3 new tires$215.11 Oil change, Antenna mast$759.13 Master Cylinder, oil change, brake flush, fuel service$505.95 3,750 service, antenna mast, O2 check$2,223.53 8 Injectors$91.49 3,750 service$846.15 MAF, checked fuel pump$464.57 Oil & transmission service (flush & replaced with Amsoil synthetic)$341.55 Knock sensor code - diagnostic service only - no replacement. Reset code$672.28 Oil change passenger window regulator$1,874.94 replace fuel pump, relay, & controller, reset knock sensor code$1,300.67 replace plugs, fuel pressure regulator$3,880.70 valve cover gaskets, brakes, water pump, hoses, battery, alignment$166.60 oil change, 7,500 mile service$350.00 Tokiko Blues
Me:$4,500.00 Purchase$14.00 left front tire$305.05 other 3 tires$178.10 sway bar bushings, strut boots$282.96 power steering line$286.72 upper links, steering boot, passenger window regulator$22.90 steering boot$180.00 Amsoil & filters$890.00 Knock Sensors & Harness, tune-up$800.00 18" ASA Revolution & Sumitomo HTR+ 245/40/18$209.95 install steering boots & alignment$315.00 Continental Sprot Contact 245/45/18$105.00 Mount & Balance tires, 4-wheel alignment$200.00 Lower Control Arm$150.00 2 New Wider Rear wheels$69.00 Subframe bushings$220.00 Drilled & Slotted rotors$100.00 Adjustable rear upper control arms$125.00 Front camber adjustment$225.00 Cali Custom Springs$125.00 NICO ECU$65.00 93 ECU$25.00 New Radio$50.00 Body Control Module$25.00 Local Control Module & control panel for driver's door$500.00 Z23 brake calipers$9,968.68 Total
