NutriaforBreakfast »
https://forums.nicoclub.com/nutriaforbreakfast-u77129.html
Wed Sep 16, 2009 7:25 am
I got these codes on my 95 Maxima ;PO325PO400
Tough thing to work on since you cant always run the engine to teststuff due to access problems, everything to get to is HOT
I dont think the knock sensor is bad. I do think the EGRproblem triggered it. Mine threw a code for the EGR valve but myvalve works and is only a yr. old as I replaced it.
For a maxima, the FSM shows how to test the EGRC Solenoid.
First you have to make sure you have power to the solenoid. Useyour multimeter and find 12 V on the male connector
Throttle body vacuum goes into the top of the solenoid.There are two openings out of the solenoid, one goes to thecharcoal canister and one goes to the EGR-BPT valve.
Basically, when the solenoid is powered, certain tubes are openor closed. When there is no power, certain tubes are open or closed.
It sounds like the solenoid is working since you said it clicks and theFSM says it should.
I tried the jumper wire thing and melted it
Does you EGR valve move when the motor is hot? Are you gettingvacuum to the valve through the hose connection? You should feehose vacuum. If you rev it up and put your hand on the diaphram you should feel it. Usegloves cause it hot. If you push up the diaphram the engine should begin to stall which is an indication the valve works. You can also use a Mytyvacvacuum pump to move it. If it wont move under vacuum the rubberdiaphram might have a hole in it or the valve is carboned up on theinside, or as you said, the passages taking exhaust from the exhaustmanifold to the valve are carboned up.
I have replaced the solenoid, EGR-BPT valve, EGR temp sensor, and thecode has not come back but my EGR valve still wont work. Going to tryto pass inspection here in TX without it working.
Please keep me posted
