jhayes9835 »
https://forums.nicoclub.com/jhayes9835-u157438.html
Sun Apr 04, 2010 5:12 am
I have a 1996 Infiniti I 30. I recently had the engine replaced with a used engine. I replaced the engine because of blown head gaskets. After the engine was replaced, it is very hard to start. When it eventually starts, the engine runs great. The used engine started and ran great before it was installed into my car.The mechanic has checked all of the sensors, (MAF, crank, etc) checked the wire harness for breaks or frays, checked the ignition switch, and checked the computer. Everything he has checked was fine.I am at a loss. The engine turns over but will not catch. When the engine turns over you can hear it cough or backfire, but will not start.
The coils are only 8 months old. I think he used the injectors that were in the used engine. He did say that the ignition key has to be in a certain position to get spark to the coils. When he checked the ignition switch, he got a new one and just plugged it in to the connector and used a screw driver to turn it on. Would the key assembly make a difference?Any ideas? What else can we look at to solve this problem?
