1996 Infiniti G20 Brake Light Switch replacement
patark
Car: Infiniti g20
Hello members of this forum,
I have a 1996 infiniti g20 and I'm pretty sure the brake light switch is bad. All 3 of my brake lights (two side ones and the top mounted one) used to work when I last checked and I recently found out that they are all out. I read many different posts and watched many videos but none were for my specific car so the placements were all different.
I can't figure out which one is the ASCD and which one is the brake light switch. I also can't even fit my hand in there to twist it off, anyone have any suggestions?
2_Liter_Turbo
Car: _________________
'96 S14 Coupe: SR20VET
'90 R32 TH1 GTR: RB26DETT
'92 S13 Fastback: SR20DET
'11 V36 Sedan: VQ25HR
'06 GMT800 2500HD: LBZ Duramax
I haven't looked for this myself, but I would definitely look through the factory service manual, you should be able to find the answer in there. If you don't have a copy, click the link in my signature to download one. Good luck!
patark
Car: Infiniti g20
Thanks for your reply. My problem is that I can't exactly fit my hand in there to twist it off, but I'll definitely look in the repair manual again to see if I missed anything.
Which exact section should I look at? I always look at the brake section but that doesn't have anything about the switch. Also, I found that this is related to my shifter being stuck in park. I'm pretty sure it's just a faulty switch because sometimes it isn't stuck in park but other times it is while the brake lights do work. Basically my lights sometime work and sometime doesn't work.
2_Liter_Turbo
I would think to look in the electrical sections, but I could be wrong (I have been plenty of times, ha ha). It definitely sounds like you have some electrical gremlins though.
