1996 I30t Rough Idle
Heath
Car: 1992 Q45, 2000 Excursion (towrig), 2003 Yukon Denali (Wife's Ride)
Any ideas or common problems??? I do have one problem under the hood that I know of... The breather tube from the valve cover to the intake is broken... The nipple on the intake side is broken off... I just got the car and that is one of the things I plan on fixing... Could this be it or is there some common problem that I haven't found yet in all my reading...
I30T
Car: 1998 INFINITI I30T
Well, i waited a little past the mileage on the sticker to change my oil recently and once i got it changed it stopped rough idling for me (although it only did it three or four times earlier in that day). It could be something as simple as that.
Heath
Well I changed the oil the second day we had the car... Mobile 1 filter and Valvoline Max Life 5w30...
NISTECH
that hose could be your problem since I believe that is your pcv inlet and its past your air flow meter. replace that and recheck it.
kblast523
Car: Bikes with motors, golf, woodworking, car restoration
If you have plug wires on your I30, that could be the problem...Seriiously, how many miles on the car and when was the last time you checked your spark plugs? I recently changed mine (interval sez 60K, experience told me 40-50K) At 45K took out the old, in with the new. Idled great. Next day, backed it out and ran rougher than H%ll. Put old plugs back in, ran just fine...Took "new" plugs back to NAPA, gots some "better" ones. Now runs fine. Point is, these cars DO NOT like cheap plugs...
Heath
What plugs do you recomend??? I haven't changed the plugs/wires since I bought the car... Other than the idle it seems to run great...
kblast523
Factory NGK's are good. I am running Autolite's. Do not let the parts jockeys sell you Bosch 4201's. The plug just isn't up to the demand of this engine. Double or Quad Platinum is the ONLY way to go, or Iridium. The factor NGK's are about $12 EA (x6), but at least you will not have to change plug wires (there are not any).
Heath
Ahhh, good to know, before I go in and look like a dumbass asking for some... Thanks for the info...
Heath
I guess I should actualy open the hood and look under there a bit more... I still need to find a new airbox for it... Or go with an aftermarket intake, one of the two...
subzero9935
Car: cars
I put ac delco rapid fire in my 99" maxima se 46000 miles are you saying that they are no good for my car?
kblast523
What I said was:"these cars DO NOT like cheap plugs..."I did not say they were no good for your car. You will probably just be a little disappointed down the road....
subzero9935
Car: cars
Well i want maximum performance what is the best ngk plug to buy that will help? thanks
NISTECH
platinum ngk's for your car from the dealer. the dealer in my sig has a look up chart for the plugs on your car. You can also purchase them there a well.
NISTECH
I30 1996-2001 QTY 6 engine VQ30DE ngk plug# PFR5G-11infiniti part# 22401-1P115 retail $11.00 eayour price online $8.25 ea
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
06 Infiniti M35 Sports
04 G35 & 99 I30-RIP
Bosch plugs got compatibility issues with Infiniti cars, based on previous postings. Get OEM plugs per Nistech's recommendation. There is a club member "elwesso" in the Infiniti forum who sells OEM plugs for a set of 4/6/8 @$7.50 each.
Rod
