1996 I30 ECM failure
Jefftreat
:help :help My AC is leaking from the internal evaporator onto the ECM, which is soaked. My mechanic thought it was my injectors, but raw gas continues to flood out, way too much gas being pumped. We tried a salvage ECM but not sure if it is good or not. I sure need an Infiniti mechanic. Thank You.
Q45tech
Sounds like you need a Nissan technican not a good mechanic.What would a mechanic do with electronic problems?
Fix the evap box drain first.
