Hello, newby here, I checked the search's for this issue, but still having trouble.
Getting P0135 & P0155, Heated oxygen sensors, both @ same time. cleared the codes, they come right back, together. Also intermittet P0136, rear oxygen sensor.
Checked fuse, ok.
new starter.
new brake light switch.
using 91 octane gas
transmission shift / lock sticks sometime's.
Is there any problem that could be causing all / part's of this ?
Possibly something damaged when I changed starter ?
Any help appreciated.
Thanks,
JC
Fuses was MISSING, darn mechanic took them out to check if any were blown, & put the fuse back in a spare slot instead of O2 fuse position..
Modified by lil.joe4 at 7:33 PM 1/30/2010
