InfinitiPete »
https://forums.nicoclub.com/infinitipete-u143279.html
Sat Nov 28, 2009 6:13 pm
Thanks for the Info , the top A/C came out easy but the shifter bezel was really stuck , removed the Radio and I unplugged evey connector then installed all the plugs back and the radio works fine , the plugs were not loose at all , could it be a bad wire? but since the wires do not get messed with why should they break? anyway it is funny how it works again , any suggestions why it started to work again? should I just re-install it? thanks.
