timvector »
https://forums.nicoclub.com/timvector-u232725.html
Fri Mar 07, 2014 9:52 pm
I have a 96 Maxima that stalled out during idle (in gear or not), starting a couple of months ago. This was infrequent but enough to make me nervous. Engine would have to be warm for this to occur.
I found the IACV easy to disassemble and clean (at 110K miles, 18 yrs old, it was a little dirty). Car ran fine for about a week, then stalled again. Cleaned the MAF sensor with MAF sensor spray; car ran for a week then stalled again. Checked for vacuum leaks, EGR valve movement; all OK. No codes were ever thrown, BTW, and car would re-start up right away, though exhaust smelled rich after stalling.
Unusual problem; difficult to find. Finally got a lead on it though; may be helpful to others: my car has a slow front oil seal leak, or perhaps a PS pump leak. This occasionally throws oil on the passenger side o2 sensor: a look at the sensor showed it had oil on it. Replaced both o2 sensors on the engine; car has run fine since then.
Reading up, the o2 sensors generate the signal based on comparing o2 level in outside air with that of the exhaust stream. In "closed loop" mode the engine tweaks injector open time to achieve an o2 level in the left and right manifolds that is right on the edge of where the sensor transitions. The o2 sensor on the passenger compartment side of the engine looked original; it had a few vent holes in the back unlike the newer Bosch replacements. I suspect now and then some oil may have been slung into the sensor: based on temp of the sensor (engine warmed up), the oil would vaporize, and block the sensor from the atmosphere side, making it look like the exhaust stream was lean. Engine control unit would then try and compensate by making the mixture more rich, so much so that idle speed would "cough" now and then. (Higher speeds were always fine).
Also, my guess is that the car would run well for a week or so after the earlier repairs because disconnecting the battery for several minutes causes the engine control unit to un-learn its tweaks for injector timing; after a week or so of driving (for me) it re-learned some questionable values based on the contaminated o2 sensor.
Still have the oil leak; car has been stellar for > 1 month; the new o2 sensor design looks less susceptible to trapping oil. So, if you are having an occasional stall at idle speed and there is an occasional oil drip in the driveway, add check the o2 sensor on the passenger side to see if it is oily to the quick-check list.
I am grateful to this forum for the info that helped me in pursuing this; hope this info helps someone in the future.
