Rob.Ellis »
https://forums.nicoclub.com/rob-ellis-u213674.html
Tue Mar 05, 2013 9:00 pm
Please tell me if I'm asking to much of you guys but I cant find anywhere else to turn. I want to know if any of the following sensors are not on the 96 R33 GTR RB26DETT (I'm sure some aren't). If someone has a list they could pass on to me containing all the diagnostic sensors that would be even better.
Sensors (OBDII fault codes included):
P0100
MAF Sensor
P0110
IAT Sensor
P0115
ECT Sensor
P0120
TP Sensor
P0125
ECT Sensor
P0130
Front HO2S RH Bank
P0135
Front HO2S Heater RH Bank
P0136
Rear HO2S RH Bank
P0141
Rear HO2S Heater RH Bank
P0150
Front HO2S LH Bank
P0155
Front HO2S Heater LH Bank
P0156
Rear HO2S LH Bank
P0161
HO2S Heater LH Bank
P0171
Fuel Injection System Lean RH Bank
P0172
Fuel Injection System Rich RH Bank
P0174
Fuel Injection System Lean LH Bank
P0175
Fuel Injection System Rich LH Bank
P0180
Fuel Temperature Sensor
P0300
Multiple Cylinder Misfire
P0301–P0306
Misfire Cylinders 1–6
P0325
Knock Sensor
P0335
CKP Sensor
P0340
CMP Sensor
P0400
EGR Function
P0420
TWC Function
P0430
TWC Function
P0443
EVAP Canister Purge Control Solenoid Valve
P0500
VSS
P0505
IACV-AAC Valve
P0600
A/T Control & Communication Line
P0605
ECM-ECCS Control Module
P0705
PNP Switch
P1150
Wastegate Valve Control Solenoid Valve
P1155
P1160
Turbocharger Boost Sensor
P1220
Fuel Pump Control Module
P1320
Ignition Signal
P1336
CKP Sensor
P1400
EGRC Solenoid Valve
P1401
Temperature Sensor
P1443
Canister Control Vacuum Check Switch
P1605
A/T Diagnosis Communication Line
P1900
Cooling Fan
I'm also aware some are missing (an additional knock sensor for example) I am interested in them too.
Im aware this is a lot to ask but any help would be GREATLY appreciated. Thanks
