1996 g20 passenger headlight stays on when lights are off
vvaffle
Car: 1991 240sx base hatch, 2009 WRX
I searched around for this but found no answer really. Essentially, my right headlight stays on all the time, even when the lights are off and the car is off. If I unplug the connector to the light, it turns off. I swapped the bulb with the one from the left side and the problem still remained on the right. Any ideas?
qship96
Car: 1996 Infiniti Q45
Find and replace the stuck relay.
SteveTheTech
Car: 15 Nissan Sentra SR
12 Infiniti G37x Coupe
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
The bulb is not your issue. You have a short to power somewhere in the circuit.
There is no relay in series with the headlights on the US market G20.
Best guess at this point is a bad headlight switch. It may have broken internally and constantly supplying power to headlight. Both headlights have dedicated switch contact inside the switch.
vvaffle
So I would just have to replace the little stalk that comes off the steering wheel column? I'm guessing I can buy that from a junkyard but is installation tricky if I have airbags in the car?
SteveTheTech
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
Just disconnect the battery and wait the required three minutes.
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Sorry but I think its 10 minutes and just disconect the airbag to be on th safe side (to diconect there should be a little plug on the bottom of the sterring wheel thats the way it is on my Q45).
SteveTheTech
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
Yep your right I stand corrected Good looking out.
The newer models are 3 minutes. Enough to allow the capacitors to discharge.
I don't think disconnecting the A/B harness is necessary since all you have to do is remove the lower steeing wheel cover and a few screws.
vvaffle
so I should just replace this whole part?
SteveTheTech
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
I cannot for some reason see your pic but I anm going to guess that the component only comes as one piece
vvaffle
It's the lever for the lights and to it is attached a box with a plug on one end of it. Is that it?
SteveTheTech
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
Yep sounds like it.
vvaffle
in case anyone searches, replacing the stalk/headlight switch worked with no problems and was very easy to do. thanks guys
SteveTheTech
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
Congrats.
