1996 G20 clutch adjustment
leeberlemann
Car: G20
I have a 1996 G20 that I need to adjust the clutch. Any tips/watch-out-for's?ThanksLee
Mr1der
you'd be better off posting this in our Sentra/G20 forum
welcome though, you'll probably have your answer on it in like 10 minutes tops.
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
Clutch adjustment is very simple. There is a thumbwheel that you use to actually adjust the cable. First you must get a 10mm wrech and pair of pliers. In front of the thumb wheel on the clutch cable is where you need to place the pliers. Now with the 10mm wrench, undo the nut so that you can turn the thumb wheel freely. All depending on what kind of adjustment you need, move the thumb wheel closer to the firewall to tighten up the clutch cable and bring the release point higher up on the clutch pedal. The other way will give the opposite effect. Once you get the clutch engagement where you want, the tighten back down the 10mm nut and enjoy.
