And the 1995 has OBD I and variable valve timing. If you swap all harnesses and modules, it probably would work and be legal.franknitty69 wrote:Hey guys,
search does not give me a definitive answer. but i need to know if a 1996 q45 engine will fit into a 1995 Q45a w/active suspension (of course) and traction control.
i know it will actually 'fit', but will it work correctly. i know the 1996 has obdII and no variable valve timing.
thanks
i wanted a 95 engine, but haven't found one yet within my price range. i find plenty 90-93's, but i'm not interested in doing a chain guide job.Q45tech wrote:Don't understand WHY one would just not find a 94-95 engine as they are plentiful whereas the 96 is very rare.
If you can get the VIN form the vehicle from which the engine was pulled, then get a service history, maybe you can get an idea where and how it was operated.Q45tech wrote:I would avoid California and Arizona domestic engines [fuels] and extreme northern states..........lots of Southern junkyards but the car could be a recent tranplant from Minnesota.
So if you are willing to send $1300 for a used engine- the condition of which can't be verified- why not get a new one for a couple hundred more?franknitty69 wrote:
found a couple of 94's, but $1300 is my limit. This 96 was going for $800 and had < 38k, but i've already passed on it since i was getting conflicting answers about compatibility.
thanks for the info fellas.
