1996 D21 brake lights stopped working
Jamesearl63
Car: 1996 Nissan pickup 4x4
My brake lights stopped working. I replaced brake light switch and lights started working again. When I went to mount new switch, heard a small pop like a fuse had blown. Now nothing on truck works except headlights. Won't start, no blinkers, no dash lights.
Reason: Revise Title
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Check your fusible links, sounds like you popped the main one.
Jamesearl63
Is main fusible link the one next to the battery? Thanks for responding.
VStar650CL
Technical Expert
I don't recall specifically on the D21's, but all the links on all the older stuff are usually right next to the battery in their own box.
whomadewho
Car: 1997 Nissan pickup
Check for poor connection at battery cables. The fuseable link is located on the positive battery cable. Remove the tape on the positive cable. The link (wire) is red in color. The link contains a rafter full of various wires. Check the wires for corrosion and good contact. Also on the passenger side near the hood hinge you will find a black box with various relays. Pull the cover on the fuse box look on the back it shows a diagram indicating the location of each fuse and what it's for. Directly above the fuse box is a row of relays. The relays are spendy. You can check them individually or borrow one example the one under the hood that controls the A/C provided the ends are the same
