marineengineer56 »
https://forums.nicoclub.com/marineengineer56-u308341.html
Mon Jan 09, 2023 10:49 am
Have a 1996 Nissan Hardbody D-21; 2WD, Automatic. Runs good when cold, stumbles when warm both at idle and running. Vacuum is 18", Fuel pressure is 34psi, has a new distributor timing is set to 10 BTDC, spark plugs are a light brown. My Zurich (HF) Scan tool will not recognize any Nissan before 1998, purchased the 14-pin plug to 16-pin plug so it Should be able to read the ECM. No luck. Looking for ideas for a scan tool that will not cost all of my grandchildren and my Harley. Also tested each fuel injector -11-12 ohms. Anybody have any ideas; the owner is retired and doesn't have a lot of money.
