hevi99 »
https://forums.nicoclub.com/hevi99-u238971.html
Fri Mar 13, 2015 3:02 pm
My dad's blower motor just stopped working overnight. I tried everything I can think of but still no go. I'd appreciate some help. I'll list everything I've tried.
First I checked all fuses and relays, they all looked good but we just replaced them anyways. I tested around with the multi-meter. No power is getting to the blower. I unplugged it put the meter on the plug cycled the fan switch it gets no reading at all. Under the hood there is a 65A fuse for the front blower that's getting 12 volts. Under the dash are 2 20a fuses for the front blower and they aren't getting anything either. So i'm guessing the problem is between the under the hood fuse box and the one inside under the dash maybe? I also replaced the blower motor resistor just to be safe, still nothing. The only thing I haven't tried was the fan switch to see if it's getting any power. I lost daylight so I might give that a shot tomorrow.
Thanks, any ideas to try would be appreciated.
