Car died while driving, got it towed home and figured it was the distributor as it had been having the oil leak issue and had been cleaning it out from time to time.. Any, replaced distributor, was not the problem so I started trying to diagnose the issue:
-pulled fuel line off fuel rail and had no gas coming while cranking over engine.
-check fuse under drivers side dash, fine.
-replaced fuel pump relay, still nothing.
-replaced fuel pump, still nothing.
checked and it has spark, a bit weak looking but spark is there.
at this point I've replaced the distributor and the fuel pump and still don't have a working car... any help would be appreciated..
