1996 240sx w/rb25det speedo issue's
band1t85
Car: 96 240sx w/rb25
i have a 96 240 with rb25det, everything works except the speedo is way off! it claims i'm doing 120mph when i shift into 3rd gear. I was told by a gentleman at mckinney motorsports that i needed to have it calibrated. If anyone can help it would be much appriciated. Thanks
flatrate
Car: S14 kouki
werid my 98 reads normal...
FinkenS14
Car: 1995 Nissan 240sx S14
My 95 reads just fine...
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
CarlH started a poll asking this question. Many have not had issues and many others have. It seems to be a hit-or-miss type of situation with the cluster being compatible with the RB25 VSS. Like McKinney suggested, you'll have to calibrate the gauge cluster. Search
240z4u
Car: '95 Nissan 240SX
Darius wrote:CarlH started a poll asking this question. Many have not had issues and many others have. It seems to be a hit-or-miss type of situation with the cluster being compatible with the RB25 VSS. Like McKinney suggested, you'll have to calibrate the gauge cluster. Search
The problem with calibrating the cluster is that your cruise won't work properly (if your keeping it) I am going to install a dakota digital contraption to modify the signal for the dash and the cruise.
Evan
band1t85
does dakota digital recalibrate the cluster then or is it something you just buy and do it yourself?
