1996 240sx SE speed sensor location
rpd240
Car: 1996 240SX SE
My car threw a check engine light and read it as a speed sensor error. I looked through the FSM but couldn't find a specific location as to where the sensor is at. I searched but didn't get any specific information. I jacked up the car and found what appeared to be three sensors on the passenger side. Two of the sensor leak gear oil when pulled out, and the last is all the way towards the top near the shifter mechanism. Am I correct in believing it is the last one? I found a diagram showing the speed sensor harness but not the exact location? The last sensor is on the tailshaft housing all the way towards the top. If needed, I can take a picture to help verify.
Modified by rpd240 at 2:12 PM 4/22/2006
180fan
Car: 89 fastback
at the back of the transmission near where the driveshaft plugs in.
NISTECH
Note the sensor at the driveshaft is the signal generator for the actual speed sensor in the speedometer. Most nissans when throwing this code have a bad speedo head.
rpd240
Car: 1996 240SX SE
Speedo head? Do you mean by the actual gauge cluster? Can you elaborate a bit?
NISTECH
The speedo head is the speedometer portion of the cluster. It comes out seperatly.
