rogoman »
https://forums.nicoclub.com/rogoman-u37451.html
Sun Mar 22, 2009 4:28 pm
To locate the bad cylinder pull off one plug wire at a time while the motor is idling; there will be no effect on idle quality when the bad cylinder is found. With the wire off the plug of the bad cylinder, plug in a spare and lay it on top of the valve cover to see if you're getting a spark. If ignition is OK, then there's an injector problem.
