Michael.Timz »
https://forums.nicoclub.com/michael-timz-u68919.html
Sat Jun 23, 2007 4:52 am
i get a high-pitched squeal in the high-RPMs in neutral as well as drive, even when the A/C is off.
everybody i've talked to about this says it's probably a belt, so this morning i check them out. they all look pretty good to me, they all seem to be pretty tight (and not too tight).. but when i was looking at the pulleys, i saw this:
(the warped section, incase the arrow was unclear)
i don't know if this could cause a squeal in high-RPMs, but if so, can someone tell me which pulley this is so i can replace it?
ALSO: i have a check engine light on, with no obvious driving/functionality problems. when i went to autozone to have the code read, the OBDII scanner didn't catch any codes. he couldn't even turn it on. i've never heard of this, does anyone here have any clue? maybe the two problems are connected?
i tried to search these two problems, but to no avail. please help
