jrb92se »
https://forums.nicoclub.com/jrb92se-u35859.html
Thu Mar 30, 2006 9:29 am
i followed the wiring it goes into a box under the dash above the clutch im going to assume this is the amp but im not positive it doesnt seem like a short cause it doesnt blow fuses if it were shorting out wouldnt the fuse blow if you rock the window back and forth it will go down but it struggles but it goes up fine mostly
