TerminalVelocity »
https://forums.nicoclub.com/terminalvelocity-u56075.html
Wed Feb 13, 2013 1:20 pm
Recently I started experiencing issues with my passenger side door window, described below.
I am unable to move the window up or down from the passenger control panel. At first I was able to move the window down from the driver side control panel (but not up), and now I can not move it in either direction. The window lockout button is not engaged.
When I apply +-12V directly to the window motor, it functions properly. Each switch has +-12V coming out of them when pushing up/down on the switch. I checked continuity across the switch to motor connector and it checks out, so I know my connection is good.
At this point I'm stumped. Any ideas on what I might be missing/what the issue is?
Edit: Additionally, with everything connected and the window switch pushed, reading voltage to the motor results in 0V. This leads me to believe it's an amplifier issue?
