matt4pl »
https://forums.nicoclub.com/matt4pl-u4587.html
Mon Oct 24, 2005 3:06 pm
a little background:
i've killed 3 alternators during this spring/summer, 2 due to oil, one due to a crapped out battery, or so i think, it was tested and both were bad so i repalced both (under warranty )
i have an optima red top
so about two weeks ago i noticed that sometimes my car would run crappy, wouldn't accelerate very well, felt like it was bogging/choking, the dummy lights would come on when coming to a stop, along with the RPM's dropping to a near stall. at night the lights would get dim. other times it would run just perfect. this is also regardless of what the sound system was doing. most recently when it happened i noticed the lights were much dimmer then usual so when i got to my friends house we checked the volatege, with the car off the battery read11.9, wiht it on it read 11.6 for batt and alternator. i also noticed a faint whirring/whinning sound when it ran crappy. i checked the positive cable running to the alternator and it looked ok, i could see some of the copper. i plan on repalcing this when i do whatever work is neccessary to fix the car anyway. i checked the tension on the belt and it seems fine, im not too sure on how much play should be in the belts. i did notice that the long tensioner bolt was almost 2 inches out and totally lose but the bolt that holds the tensioner bolt the the alternator and to the tensioner bracket was very tight and i could not more the alternator around by hand. i'm sort at a loss here so i dunno what the next thing i should check is. i didn't get to see much cause it was night out. any ideas or help would be greatly appreciated
