Nismoaniak »
https://forums.nicoclub.com/nismoaniak-u137471.html
Mon Aug 31, 2009 5:06 pm
ok so since last time.. ima put it like this.
The engine did not turn over, and i found water in the engine after all, in the part where you actually poor the oil into the engine. i stuck my finger in there and sure enough i saw on my finger water and oil. so i decided 2 do more research again on buying another engine,.. man i keep getting let down!
i found an SR20DE for $598.00 total price. it is a used engine imported from japan. now around where i live, i have heard of places that import them, but EVERYONE says that they guarantee it has 50,000 miles or less. already thats a bit iffy to me. the lady said they guarantee the engine for 6 months and if anything goes wrong with it, they replace it for me. Another funny thing, they dont ask for my engine as a core! weird. she also assured me that they compression test the engine, but when i asked for a copy of that she said they dont have it for me; and i asked why but she never gave me a straight answer. so with that info i left and started pondering a bit. Hmmm what should i do? lots of things are iffy to me, but if i can get all she says in writing maybe ill go for it. I decided to ask my friends dad to help me in this matter, he is the type of person 2 make sure i dont get screwed over, and would make sure they include everything they say.
Now i asked the lady what the shop recommended i change on the car, parts wise. she said they recommend i change the following, "cam seal, crank seal, rear main seal, water pump." when i told my friends dad this, he didnt like it at all. he said i should run! I almost had a heart attack! thats not what i wanted to hear. he said "the engines busted, that means the Cam is warn, Crank is warn, might need to replace the head gasket, Pistons are worn" and then he also asked me for the year of my car and the condition its been in(non opp in the back yard etc.) so then he says.... "your going to want to replace the radiator, alternator, water pump, front U joints, master brake cylinder and more..."
He estimated about $2000 to fix all that. and that i have to do all the work my self. Basically he thinks the car is not worth it and that i should buy another car. oh and the whole reason he said that is because, the car has about 150,000 miles on it give or take. so apparently my car is only good for 200,000 miles. so thats why i have 2 completely overhaul my car.
Ohhh but i want my car 2 run sooo bad! please someone tell me this isnt true and that my car is still salvageable. i mean all it needs is an engine! right?
Allow me to describe my frustrations.. .... yea that about summs it all up.
HELP! Please lol AY ya yay ima pray to the Nissan gods!
