1996 200sx after air filter and battery change
blindman1
Car: 1996 200SX
I have a 1996 200SX SE-R. I changed the battery and air filter. Now it has the check engine light on and won't go over 2000 RPM. It surges bad at about 2000 RPM. Did something come unhooked at the air intake? It ran fine before.
5upra
Car: S197
Get CEL checked at autozone.
OldmanPurdy
Car: 2002 Nissan Altima SE 3.5
Check the maf sensor, its usualy a black box directly after the air filter and if its unhooked/damaged it will limit the rpms to 2 - 3k.
xekushnr
Car: '90 Nissan 240SX Hatch
that sounds exactly like the mass airflow sensor. with the car on, try jiggling the wire to the MAFS around. if you dont know, its the sensor closest to the air filter in the air intake. make sure you didnt forget to hook it back up.
