Hi Elwesso,Thanks for the reply.I have been in touch with infintipartsusa and they said they can supply me a FX45 sump, but as you say they are different to the VHs. We could look at modifying it , but the stupid thing is, if I can find a front cut/motor in japan of one of these babies (VH41 AWD) they are only $3000 max for a front cut and about$2000 max for an engine package. Stupidly cheap, they don't charge any extra for the AWD version, just got to find one!Our other option we are researching is a dry sump setup with an independent front diff housing mounted to the chasis. As opposed to the sump mounted diff set up. Could work if we have to!Good point about the amount of oil in the 41s pan!Maybe dry sump is the way after all! I suppose at 8000rpm you don't want a lack of oil do you!We have several importers looking for me and the Engine builder, who is in NZ, is looking too. But patience is not one of my virtues!, especially when we need this sorted before we can begin anything else.
elwesso wrote:Wow, thats cool! I would think that most people never new that the cima came in AWD with the V8.... NICE, japan gets all the cool stuff.
Anyway, I think youd have to talk to someone in japan about this, since they were never offered to my knowledge outside of japan.
The VK45 oil pan is different from the VH4x oil pan however you might be able to modify it to work... I think you're probably going to have to custom make a pan, by the time you get done modifying a stock pan it may just be better to have a new one made for the application. Plus youd like to have more than the wimpy 6 quarts the VH has!
